Portable Sound Forge Audio Studio 9.0.0.85 - 30,2 MB
Sound Forge Audio Studio software is everything you need for audio editing and mastering professional-quality audio on your home computer. Record live instruments and vocals, edit and restore audio, apply studio-quality audio effects, and convert files with lightning speed. You can even create your own karaoke tracks with included vocal remover software, Vocal Eraser. Best of all, Sound Forge Audio Studio audio editing software is easy to use. With a few basic commands such as cut, copy, and paste, you can produce high-fidelity audio on your PC.
Capture & Record
Import music from your own CDs and MP3s, record live performances, capture audio from vinyl, cassettes, and more. Just plug in your microphone, instrument, or playback device and let Sound Forge Audio Studio software do the rest.
Edit & Mix
Experience pro-level control over audio editing and effects processing. Mix audio tracks, apply effects, restore damaged recordings, remove vocals, and synchronize audio with video.
Save & Share
Sound Forge Audio Studio software has powerful encoding tools so you can save audio and video in popular formats including MP3, WAV, WMV, and QuickTime®. Multiple export options make it easy to burn your own CDs, export audio to your MP3 player, or upload songs to the web.
