Paralells Desktop v3 build 5584 MACOSX
The killer app for Mac is now even better than ever!
Run Windows, Linux, and more side-by-side with Mac OS X on any Intel-powered Mac, without rebooting. With Parallels’ award-winning virtualization technology, you can run Mac OS X and Windows at the same time. You can even drag-and-drop files between desktops!
Leading the way with our trademark innovation, Parallels Desktop 3.0 comes packed with 50+ new features and enhancements, including Snapshots, 3D graphics, and the new Parallels-only SmartSelect.
Still using a previous version? Discover why you should upgrade to Parallels Desktop 3.0.
With Parallels Desktop 3.0 you can:
* Enhanced! Enjoy improved Mac OS X Leopard
* New! Use two identical CD/DVD drives in your Parallels virtual machine
* Run Windows programs like native Mac applications with Parallels Coherence, now with Apple Expose’ and transparent windows support
* New! Open Windows files with Mac apps and Mac files with Windows apps using Parallels SmartSelect
* Share files and folders between Windows and Mac OS X
* New! Access Windows folders and files without launching Windows using Parallels Explorer
* New! Run selected PC-only 3D games and graphics applications on your Mac
* Enhanced! Achieve maximum performance by leveraging Intel® Virtualization Technology
* New! Protect your Windows virtual machine with Parallels Snapshots
* New! Map Mac folders to Windows letter drives for quick and easy access to your favorite Mac files
* New! Keep your favorite files at your fingertips. Windows now mirrors the contents of your Mac’s Home Directory.
* And more!
OS : Mac OS® X Tiger 10.4 or higher running on an Intel® Mac.
FILES : 1X74.9mb
COMPRESS: WinRar
LANGUAGE: English
FIX : Serial
Code:http://www.parallels.com/en/products/desktop/
Code:Added Recovery Record and Tested -: http://rapidshare.com/files/127861955/Prallels__Dsktp305584.rar
Code:4shar1ng
