FairStars Audio Converter Pro 1.19 Incl. Keygen AT4RE l 5 MB
FairStars Audio Converter Pro is a professional audio file conversion tool to convert WAV, RealMedia (RM, RA, RMJ, RAM, RMJ, RMVB), AIF, AIFF, AIFC, AU, Creative VOC, PVF, PAF, IFF, SVX, APE, FLAC, OGG, VQF, MP1, MP2, MP3, MP4, M4A, M4B, AAC, AMR, AWB, WMA, WMV, ASF To WMA, MP3, AAC, M4A, AMR, AWB, VQF, OGG, FLAC, APE, WAV formats. You can convert multiple files in a single batch, regardless of their source and target formats. In addition, the program includes a built-in player. The audio format conversions are performed without any temporary files, allowing high conversion speeds. Other features include normalization (adjust volume), support for ID3 tags and more. FairStars Audio Converter Pro is an Audio Converter with new architecture, and have many enhanced feature than FairStars Audio Converter. FairStars Audio Converter Pro has the follow enhanced feature:
(1) Automatic extracting Audio CD Image (Audio File + CUE) to audio files which contained individual audio track content.
(2) Set or batch set output Tag.
(3) Move or copy output files by Output window easily.
(4) More flexible settings for the items in Task List.
(5) Support Lossless and Professional codecs for WMA format.
(6) More flexible settings for encoder.
(7) More Easy-to-use user-friendly interface, and skin support.
...and much more.
Main features:
• Convert WAV, RealMedia (RM, RA, RAM, RMJ, RMVB), AIF, AIFF, AIFC, AU, Creative VOC, PVF, PAF, IFF, SVX, APE, FLAC, OGG, VQF, MP1, MP2, MP3, MP4, M4A, M4B, AAC, AMR (AMR-NB + AMR-WB), WMA, WMV, ASF To WMA, MP3, AAC, M4A (MP4 Audio), AMR (AWB), VQF, OGG, FLAC, APE ,WAV formats with different settings.
• Fast Conversion Speed: audio format conversion is performed directly without any temporary files, and thus enables high converting speed and economy of hard disk resource.
• Batch audio files conversion:You can convert many files in one batch regardless of their source formats.
• Automatic extracting Audio CD Image(Audio File + CUE) to audio files which contained individual audio track.
• Support automatic volume adjustment(normalization) when converting.
• Batch output Tag settings, and also support ID3 tags display and edit.
• Move or copy output files by Output window easily.
• Playback of Popular Music Formats with its built-in player.
• Support Drag and Drop: supports dragging and dropping files or folders from the File Explorer into the window of the converter.
• Explorer-like file input dialog: allows you to navigate through supported files on your computer and add them to File List easily and quickly.
• Easy-to-use user-friendly interface, and skin support.
Supported File Formats:
• Input Formats: WAV, RealMedia (RM, RA, RAM, RMJ, RMVB), AIF, AIFF, AIFC, AU, Creative VOC, PVF, PAF, IFF, SVX, APE, FLAC, OGG, VQF, MP1, MP2, MP3, MP4, M4A, M4B, AAC, AMR(AMR-NB + AMR-WB), WMA, WMV, ASF etc.
• Output Formats: WMA, MP3, AAC, M4A (MP4 Audio, iPod MP4 Audio, iPhone MP4 Audio), AMR (AMR Narrowband), AWB (AMR Wideband), VQF, OGG, FLAC, APE, and WAV formats.
System Requirement:
• Windows 2000/XP/XP MCE/2003/Vista/2008/7
• Full-duplex sound card.
Changes in version 1.19:
- Add "Show input files' full path" option.
- Correct an error that conversion failed when wma encoder was set as auto mode sometimes.
- Correct an exception error caused by resampling multi-channel operation.
Homepage - http://www.fairstars.com/audio_converter_pro/
Click Here
